Vegas Pro - ошибка ProType Titler: Microsoft Unified Unhandled Exception
Решено Vegas Pro - ошибка ProType Titler: Microsoft Unified Unhandled Exception
При открытии в Vegas ProType Titler результат ошибка - Microsoft Unified Unhandled Exception.
Подробнее:
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at ScriptPortal.MediaSoftware.TextGen.WidgetLibrary.TitlerEditor.MetaText_AutomationQuery(Editor editor, Widget sourceWidget)
at ScriptPortal.MediaSoftware.TextGen.WidgetLibrary.MetaObjectEditor.UpdateChecks(Boolean recursive)
at ScriptPortal.MediaSoftware.TextGen.WidgetLibrary.MetaObjectEditor.OnDataContextChange(Boolean typechange)
at ScriptPortal.MediaSoftware.TextGen.CoreGraphics.Node.set_DataContext(Object value)
at ScriptPortal.MediaSoftware.TextGen.WidgetLibrary.TitlerEditor.preview_SelectionChanged(String selectionBinding, Boolean dataModified)
at ScriptPortal.MediaSoftware.TextGen.WidgetLibrary.MetaTextDirectEditor.UpdateSpanProperties()
at ScriptPortal.MediaSoftware.TextGen.WidgetLibrary.MetaTextDirectEditor.edit_Changed(Boolean cursorOnly, Boolean forceUpdateSpanProperites)
at ScriptPortal.MediaSoftware.TextGen.WidgetLibrary.MetaTextDirectEditor.EditState.MoveCursor(Int32 position, Boolean extendSelection, Boolean skipImeSeek)
at ScriptPortal.MediaSoftware.TextGen.WidgetLibrary.MetaTextDirectEditor.MetaTextDirectEditor_Drag(Point ptDelta, MouseState ms)
at ScriptPortal.MediaSoftware.TextGen.CoreUI.Widget.OnDrag(Point ptDelta, MouseState ms)
at ScriptPortal.MediaSoftware.TextGen.CoreUI.WidgetHost.form_MouseMove(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseMove(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at ScriptPortal.MediaSoftware.TextGen.ControlLibrary.WidgetHostControl.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1099.0 built by: NETFXREL4STAGE
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Interop
Assembly Version: 14.0.0.252
Win32 Version: 14.0.0.252
CodeBase: file:///C:/Program%20Files/VEGAS/VEGAS%20Pro%2014.0/Interop.DLL
Проверил - в системе установлен Microsoft .NET Framework 4.6.2.
После повторной установки Microsoft .NET Framework 4.6.2 (веб-установщик) для Windows 7 с пакетом обновления 1 (SP1) -
Внешняя ссылка все заработало штатно!
