FAQ Vegas Pro монтаж видео – видеоредактор водномоторника
PMS
Re: FAQ Sony Vegas монтаж видео - видеоредактор водномоторника
Сообщение PMS »
Да там кроме конвертора куча всего....
Катер Амур-3 Питер
Тексты переводить умеет?
PMS
Сообщение PMS »
Шу-ту-ни-к однако...
Катер Амур-3 Питер
Ты же не рассказываешь о том, что ОНО там умеет, я вот и подумал о том, чего не умеет Вегас.
Вышла обновленная версия Vegas Pro 12.0 (Build 563)
Whats New and otable fixes/changes in version 12.0 (Build 563):
● Added support for rendering 24p AVC-Intra 100 Panasonic P2 video to a folder on your computer or to a connected P2 camera..
● Improved performance for decoding XAVC 4K video from Sony F5/F55 cameras.
● Added support for exporting event timestretching as velocity when exporting to Final Cut Pro X format.
● Added support for exporting event pan and crop settings as motion when exporting to Final Cut Pro X format. Please note that event zooming, cropping, and scaling are exported as separate operations.
__● To export event zoom, the Event Pan/Crop Maintain aspect ratio control must be set to No, and Stretch to fill frame must be set to Yes.
__● To export event crop, the Event Pan/Crop Stretch to fill frame control must be set to No.
__● To export event rotation, the Event Pan/Crop Stretch to fill frame control must be set to Yes.
● Added support for importing event pan and crop settings when importing a Final Cut Pro X format.
● Timecode for MOV files is now read properly and displayed in Vegas Pro media properties.
● Added support for reading and rendering up to 16 channels of audio in SD OP1a MXF files.
● Added new rendering templates to the Sony AVC/MVC format: use Internet 1920x1080-30p and Internet 1280x720-30p to render HD video for Internet distribution.
● Fixed a bug that could cause a crash when using Tools > Selectively Prerender Video.
● Fixed a bug that could cause a crash when browsing in the Vegas Explorer when the Documents library was empty.
● Fixed a bug that could prevent Windows Explorer libraries from being displayed in the Vegas Pro Explorer after refreshing the Explorer window.
● Fixed a bug that prevented inserting busses, input busses, and assignable effects after opening and closing the Render As window.
● Fixed a bug that could cause the application to freeze when loading thumbnail images in the Project Media window.
● Fixed a bug that could cause the Video Preview window to display red when choosing Clipboard from the Split-Screen View buttons drop-down list.
● Fixed a bug that could cause problems drawing audio peaks or saving files when using Open in Sound Forge or Open Copy in Sound Forge.
● Fixed a bug that could prevent Vegas Pro from starting when using a non-Administrator user account.
Для скачивания ОФсайта требуется регистрация! PS Надо иметь в виду, что предыдущий билд 12й версии довольно часто "падал" по непонятным причинам.
Последний раз редактировалось Valery 06.04.2013 08:26, всего редактировалось 1 раз.
Решено Sony Vegas - как вернуть стандартные настройки по умолчанию
Если чего-то нащелкал в настройках Sony Vegas и программа не работает как надо (как раньше), не спешите ее переустанавливать - эти припарки будут бесполезны. Достаточно вернуть стандартные настройки по умолчанию:
Удерживая Ctrl+Shift запустить Sony Vegas, появится окошко с предложением сбросить настройки по-умолчанию:
[attachimg=1]
OK - и у нас стандартные настройки.
Последний раз редактировалось Valery 13.03.2014 04:31, всего редактировалось 1 раз.
AC-52
Сообщение AC-52 »
Valery Здравствуйте! на форуме почти год нет коментов,форум актуален?
Приветствую!
Это же не болталка о жизни - всем все понятно.
Неактуальное при возможности заменяется на актуальное в первом сообщении темы: « Последнее редактирование: 03.03.2014, 13:14 от Valery »
Вышла новая версия Sony Vegas x64 (Build 770) - четвертый день работает без вылета. Для 12й версии - это очень стабильная работа.
Последний раз редактировалось Valery 13.03.2014 04:34, всего редактировалось 1 раз.
AC-52
Сообщение AC-52 »
Valery Здравствуйте! Помогите разобраться с форматом AVCHD как его отрендерить  в Вегасе у меня не чего не получается,прочитал Ваш урок "продвинутый монтаж AVCHD видео и обработка в SB от А до Я в нем не понимаю пункт 6  Рендерим эвенты в новые файлы (пакетный просчет в Sony Vegas) для окончательного монтажа в отдельную папку - MXF HD422 50Mbps или некомпресс используя скрипт BatchRender+Events от Chainick.
Скачать скрипт- * BatchRender+Events.zip (10.58 кБ - загружено 80 раз.)
Удаляем MTS, жмем молнию и работаем далее уже с новыми файлами - проект шевелится значительно быстрее. если можно разжуйте пожалуйста по шагово все действия,особенно со скриптом? За раннее спасибо!
Там конечно коротко рассказано очень, поправлю сейчас - т.к. этим как раз и занят, но тем не менее: говори конкретнее что не получается?
Скрипт рендерит эвенты на ТЛ в новые файлы в указанную папку для более легкого монтажа, и располагает их на новую дорожку выше. Т.е. если у тебя был файл 1Гб на пару минут, в проекте использовано 10 сек, и таких файлов куча - проект грузится и крутится тяжелее, нежели только тот кусок этого файла, который задействован в проекте, да еще и в более легком для монтажа формате.
Про "молнию" описано здесь - Сохранение и архивирование разрозненного проекта для дальнейшей работы.
ЗЫ я рендерю эвенты кодеком Cineform.
Как-то так что ли...
